How To Adjust Steaming Quality?
I am getting buffering issues when trying to stream large files. I used to be able to look at "Plex Media Server.log" to see the speed at which Plex is transcoding. However, that information seems to be missing now from my log (see below). That's question #1 - how can I monitor the speed at which Plex is transcoding? Why isn't it in my logs? Question #2 is: Is there any way to set the streaming quality on the Xbox One? I can't seem to find it.
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG - Request: [192.168.1.134:55676] GET /:/timeline?ratingKey=198928&key=%2Flibrary%2Fmetadata%2F198928%3FincludeRelated%3D1%26includeRelatedCount%3D0&state=playing&time=6223431&duration=13348032 (5 live)
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG -  * ratingKey => 198928
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG -  * key => /library/metadata/198928?includeRelated=1&includeRelatedCount=0
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG -  * state => playing
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG -  * time => 6223431
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG -  * duration => 13348032
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG - We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG - Came in with a super-token, authorization succeeded.
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG - Client [rikcuolh92z8] reporting timeline state playing, progress of 6223431/13348032ms for guid=, ratingKey=198928 url=, key=/library/metadata/198928?includeRelated=1&includeRelatedCount=0, containerKey=, metadataId=198928
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG - Play progress on 198928 'Ben-Hur' - got played 6223431 ms by account 1!
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG - [Now] User is dustinhansen (ID: 1)
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG - [Now] Device is Xbox One (DUSTS-XBOX-ONE).
Oct 17, 2014 20:35:29 [0x10cd2b000] DEBUG - [Now] Updated play state for /library/metadata/198928?includeRelated=1&includeRelatedCount=0.
Oct 17, 2014 20:35:29 [0x10cd2b000] VERBOSE - Completed request: GET /:/timeline?ratingKey=198928&key=%2Flibrary%2Fmetadata%2F198928%3FincludeRelated%3D1%26includeRelatedCount%3D0&state=playing&time=6223431&duration=13348032: 2200
Oct 17, 2014 20:35:29 [0x10d1ea000] VERBOSE - Finished writing response for GET /:/timeline?ratingKey=198928&key=%2Flibrary%2Fmetadata%2F198928%3FincludeRelated%3D1%26includeRelatedCount%3D0&state=playing&time=6223431&duration=13348032, 0 bytes in 34ms
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG - Request: [192.168.1.134:55677] GET /:/timeline?ratingKey=198928&key=%2Flibrary%2Fmetadata%2F198928%3FincludeRelated%3D1%26includeRelatedCount%3D0&state=playing&time=6226234&duration=13348032 (5 live)
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG -  * ratingKey => 198928
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG -  * key => /library/metadata/198928?includeRelated=1&includeRelatedCount=0
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG -  * state => playing
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG -  * time => 6226234
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG -  * duration => 13348032
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG - We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG - Came in with a super-token, authorization succeeded.
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG - Client [rikcuolh92z8] reporting timeline state playing, progress of 6226234/13348032ms for guid=, ratingKey=198928 url=, key=/library/metadata/198928?includeRelated=1&includeRelatedCount=0, containerKey=, metadataId=198928
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG - Play progress on 198928 'Ben-Hur' - got played 6226234 ms by account 1!
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG - [Now] User is dustinhansen (ID: 1)
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG - [Now] Device is Xbox One (DUSTS-XBOX-ONE).
Oct 17, 2014 20:35:32 [0x10df9e000] DEBUG - [Now] Updated play state for /library/metadata/198928?includeRelated=1&includeRelatedCount=0.
Oct 17, 2014 20:35:32 [0x10df9e000] VERBOSE - Completed request: GET /:/timeline?ratingKey=198928&key=%2Flibrary%2Fmetadata%2F198928%3FincludeRelated%3D1%26includeRelatedCount%3D0&state=playing&time=6226234&duration=13348032: 2200
Oct 17, 2014 20:35:32 [0x10d1ea000] VERBOSE - Finished writing response for GET /:/timeline?ratingKey=198928&key=%2Flibrary%2Fmetadata%2F198928%3FincludeRelated%3D1%26includeRelatedCount%3D0&state=playing&time=6226234&duration=13348032, 0 bytes in 3ms
Oct 17, 2014 20:35:32 [0x10d26d000] VERBOSE - Finished writing response for GET /video/:/transcode/universal/session/s7f48iy7r2mm/base/00622.ts, 23611108 bytes in 20225ms
Oct 17, 2014 20:35:32 [0x10d26d000] VERBOSE - [IDLE] Removing (1->0) work item http_download - /video/:/transcode/universal/session/s7f48iy7r2mm/base/00622.ts
Oct 17, 2014 20:35:32 [0x10d26d000] VERBOSE - [IDLE] * transcoder - s7f48iy7r2mm - 1 active item(s)
Oct 17, 2014 20:35:33 [0x1075d5000] DEBUG - Request: [192.168.1.134:55678] GET /video/:/transcode/universal/session/s7f48iy7r2mm/base/00623.ts (4 live)
Oct 17, 2014 20:35:33 [0x1075d5000] DEBUG - Asked for segment 623 from session.
Oct 17, 2014 20:35:33 [0x1075d5000] DEBUG - HLS segment range: 539 - 980 average bitrate: 11.83 Mbps
Oct 17, 2014 20:35:33 [0x1075d5000] DEBUG - Returning segment 623 from session: /var/folders/dw/m8pnwn2j7bz23mdfxgzycwpm0000gn/T/plex-transcode-s7f48iy7r2mm-8ff61cde-065c-4e0a-8e7e-ab7856e48f27/media-00623.ts
Oct 17, 2014 20:35:33 [0x1075d5000] VERBOSE - [IDLE] Adding (0->1) work item http_download - /video/:/transcode/universal/session/s7f48iy7r2mm/base/00623.ts
Oct 17, 2014 20:35:33 [0x1075d5000] VERBOSE - [IDLE] * http_download - /video/:/transcode/universal/session/s7f48iy7r2mm/base/00623.ts - 1 active item(s)
Oct 17, 2014 20:35:33 [0x1075d5000] VERBOSE - [IDLE] * transcoder - s7f48iy7r2mm - 1 active item(s)
Oct 17, 2014 20:35:33 [0x1075d5000] DEBUG - Content-Length of /var/folders/dw/m8pnwn2j7bz23mdfxgzycwpm0000gn/T/plex-transcode-s7f48iy7r2mm-8ff61cde-065c-4e0a-8e7e-ab7856e48f27/media-00623.ts is 31464620.
Oct 17, 2014 20:35:33 [0x1075d5000] VERBOSE - Completed request: GET /video/:/transcode/universal/session/s7f48iy7r2mm/base/00623.ts: 2200
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG - Request: [192.168.1.134:55679] GET /:/timeline?ratingKey=198928&key=%2Flibrary%2Fmetadata%2F198928%3FincludeRelated%3D1%26includeRelatedCount%3D0&state=playing&time=6229000&duration=13348032 (4 live)
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG -  * ratingKey => 198928
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG -  * key => /library/metadata/198928?includeRelated=1&includeRelatedCount=0
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG -  * state => playing
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG -  * time => 6229000
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG -  * duration => 13348032
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG - We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG - Came in with a super-token, authorization succeeded.
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG - Client [rikcuolh92z8] reporting timeline state playing, progress of 6229000/13348032ms for guid=, ratingKey=198928 url=, key=/library/metadata/198928?includeRelated=1&includeRelatedCount=0, containerKey=, metadataId=198928
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG - Play progress on 198928 'Ben-Hur' - got played 6229000 ms by account 1!
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG - [Now] User is dustinhansen (ID: 1)
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG - [Now] Device is Xbox One (DUSTS-XBOX-ONE).
Oct 17, 2014 20:35:35 [0x10ea19000] DEBUG - [Now] Updated play state for /library/metadata/198928?includeRelated=1&includeRelatedCount=0.
Oct 17, 2014 20:35:35 [0x10ea19000] VERBOSE - Completed request: GET /:/timeline?ratingKey=198928&key=%2Flibrary%2Fmetadata%2F198928%3FincludeRelated%3D1%26includeRelatedCount%3D0&state=playing&time=6229000&duration=13348032: 2200
Oct 17, 2014 20:35:35 [0x10d26d000] VERBOSE - Finished writing response for GET /:/timeline?ratingKey=198928&key=%2Flibrary%2Fmetadata%2F198928%3FincludeRelated%3D1%26includeRelatedCount%3D0&state=playing&time=6229000&duration=13348032, 0 bytes in 6ms
Not sure about the logs, but for setting the streaming speed: While watching a movie hit A, go to the right and hit the ellipses button (...), this will have the different speeds on the right side that you can select.
Thanks.
