How to allow preroll for managed users
What I have
I’m running a plex instance in docker off my local NAS with libraries shared to users outside my house. Users have been using it for years without issue.
I’ve recently added a preroll clip to my library- it works great on my end; when I play a movie I can see the preroll just fine. But external users are unable to see it (they have opted into preroll via the player setting Cinema Trailers to Play Before Movies).
My preroll path is something like /extras/preroll.mkv.
What I want
External users should see the preroll clip before their movies on my shared libraries if they have opted in, enabling trailers in their own plex player (be it webOS app or the website).
What I’be tried
I’ve seen a few posts mentioning preroll needed to be in shared libraries to be played by external users and links to it should be used instead of filesystem paths; I tried this without luck, but I don’t know if I did what was ‘correct’ or ‘sufficient’ because I cannot find any guide or information on how to actually do this; the posts comments just mention those bits of information in passing while talking about other problems.
Is it possible that my users also have to be plex pass subscribers? Does it have to be in the same shared library or just a shared library they have access to? Or is anyone able to provide documentation / insight about how to enable this?
Are you checking with the same movie library that you are sharing? There is a per library setting to enable this too. Make sure it’s enabled for the shared library.
Per library I have:
  1. “Enabled Cinema Trailers” enabled
  2. “Only show trailers” disabled
  3. “Allow red band trailers” enabled
  4. “Find extras” enabled
If what you are referring to is not in the items listed above, accessed via Manage -> Libraries -> LibraryName -> Edit Library -> Advanced, please let me know. Thanks!
Oh sorry. I was thinking it was trailer that were not working. For pre-roll, none of those settings are applicable. As long as you’ve enabled the pre-roll value and set it for at least 1 cinema trailer, you should see the pre-roll.
Can you play a movie as the managed user and then get me your server log so I can check what is going on.
It seems to have been a GPU issue; updating drivers on his end seems to have fixed the issue; maybe it was failing to transcode or something? Thanks!
And for those reading for future reference:
Filesystem paths are sufficient, the preroll video does not need to be in the library, and guest users do not need plex premium.
