How to configure my Air i7 RII mini remote to fully work with RasPlex
I’m struggling already for a long time to get my Air I7 mouse (see picture) fully working with RasPlex.
Some keys work by default (navigation, ok, play/pause), but keys like Home button do not.
I’m trying to adapt keymaps files, but without success :frowning:
I wonder if someone already got this mouse working with RasPlex (which adapted keymap files, where to store these?).
Any help is welcome
BR Martie
Ah, same remote, same problem. I can navigate the menus but not select anything on account of the OK button and no way to get back to higher menu’s. :expressionless:
I have a similar problem. Not the same brand of remote, but it looks as though it has the same keys.
Hi
You all need to configure the keys in the keyboard.xml
follow the instructions of how to capture the keypresses in the LIRC configuration
Those controllers are usually just detected as an USB keyboard HID but you must learn which key is what and represent them in the keyboard.xml file.
Only if you get something like CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(304) you wont be able to map that key
Sorry but its something you need to do yourself as each remote is different
