Wireless Remote Not Working
Hi Everyone
I have recently purchased a Raspberry Pi 2 and a Rii 2.4G Wireless Air Fly Mouse Remote.
I installed Rasplex which works great and the remote works great but the back button doesn't work.  The back button does work if I install OSMC, but as I am a Rasplex fan this is not a solution for me.  So I have done some research and have been trying to add a key mapping for the key but it seems like Rasplex is ignoring my keyboard.xml / remote.xml files.
I created a keyboard.xml and copied it to /storage/.plexht/userdata/ which didn't work, I also copied it to /storage/.plexht/userdata/keymaps which didn't work
and then I tried the same but renamed the file to remote.xml with no success.
Further just to see if my xml file is being processed I downloaded a standard keyboard.xml file from github (see attached) and simply mapped all the right keys to the same as the
left keys just as a test, but still all is ignored.
I copied the xml files with winscp signing in with root and rasplex.
Anybody able to assist with where I am going wrong...
