How to create a recording between a start time and an end time
When the program guide is missing, I would like to be able to create a daily recording of a given channel between a specific start time and an end time.
How can I do this?
Unfortunately, you cannot.
Recording jobs are always tied to a specific EPG item.
If you are trying to record a programme which is broken up into two events on the EPG (with perhaps a news show inbetween), schedule the first part for recording.
Then edit the recording job and define “Minutes after End” to cover both the break and the second part.
If there is no EPG at all for this channel, you are unfortunately out of luck.
Thank you for your reply.
The EPG has been missing information for this French channel (and only this one) for 48 hours. I hope this won’t last.
Have you tried manually refreshing the guide data?
Yes, I’ve tried this morning …
Does anyone know from whom Plex obtains the program guide (at least in France)?
EPG is back today !
But it should be nice to be apple to plane a record with timestamp …
