How to debug theTVDB agent's failure to work with Japanese files
I have verified that the show (相棒)exists if you search using 日本語:
http://thetvdb.com/index.php?tab=series&id=188501&lid=25
and I have specified the language as 日本語 in the advanced options for the section. The naming is correct, and the scanner is finding the shows correctly, but no metadata is getting added:
./相棒
./相棒/
./相棒/Season1
./相棒/Season1/相棒 - S1E10.avi
./相棒/Season1/相棒 - S1E11.avi
How do I figure out what is going wrong? Are there useful logs to look at? Is there anyway to see what the agent is actually looking up?
--Matt
Look in PMS Plug-in Logs/com.plexapp.agents.thetvdb.log for any suspicious failures.  If you attach that one as well as the Scanner log here I can take a look.
Annoyingly, I don't see any obvious errors. In fact, I see what appears to a successful fetch of the right thing:
2013-12-17 16:33:10,950 (1126ca000) :  DEBUG (networking:172) - Requesting 'http://freebase.plexapp.com/tv/names/ja/0e/0e9ffe2f599f1bfa5df17148160aea3272b7ffb6.xml'
2013-12-17 16:33:11,126 (1126ca000) :  INFO (__init__:407) - ****************** mediaShowYear: %E7%9B%B8%E6%A3%92
2013-12-17 16:33:11,126 (1126ca000) :  INFO (__init__:79) - Retrieving URL: http://thetvdb.plexapp.com/api/GetSeries.php?seriesname=%E7%9B%B8%E6%A3%92&language=ja
2013-12-17 16:33:11,156 (1126ca000) :  DEBUG (networking:172) - Requesting 'http://thetvdb.plexapp.com/api/GetSeries.php?seriesname=%E7%9B%B8%E6%A3%92&language=ja'
2013-12-17 16:33:11,387 (1126ca000) :  DEBUG (runtime:914) - Response: [200] str, 628 bytes
I don’t suppose anyone knows what else I should look at? This is clearly broken, but I’m not sure why.
–Matt
Sent from my Nexus 5 using Tapatalk
code 200 is OK
http://thetvdb.plexapp.com/api/GetSeries.php?seriesname=%E7%9B%B8%E6%A3%92&language=ja is valid and return:
188501
ja
相棒
graphical/188501-g.jpg
"Tokumei Gakari" that's the dead wood post in Tokyo Metropolitan Police Department called the graveyard of the human resources. Ukyo Sugishita police inspector who dropped out of the upward trajectory because of a strange character though he has perfect career and too excellent brain belongs to Tokumei Gakari. a hot-blooded person, an honest person's Kaoru Kameyama that does the blunder and has been made to the object of the dismissal is relegated to Tokumei Gakari. Ukyo and Kaoru that became a partner solve the accident case. (until the season 7 episode 9) but Kaoru resigned from a detective in the season 7. Though Ukyo was single for a while, Takeru Kanbe sent into Tokumei Gakari for Ukyo investigation by the instruction of Tokyo Metropolitan Police Department top management, will succeed the partner position in place of Kaoru.
2002-10-09
TV Asahi
188501
metadata is present and seen...
I don't suppose anyone knows what else I should look at? This is clearly broken, but I'm not sure why.
If you upload the logs I asked for, I can take a look.  Hard to say otherwise.
attach the whole log
the 628 bytes seem wrong since i pasted the code and it's 1111 bytes.
you could amend the logs to be able the file loaded in data folder but pasting the full log is the easiest way forward
