Tv Shows Metadata and Scanner - Somes series not coming up
For some of my TV Shows I noticed that some of my shows don’t have images. For either the Cover or the Episodes, What I’m after is to have the synopsis of each episode and the cover art with the episode title.
What I’m using to get the names of the files is Filebot using the TV Database that it uses. So I assume that its all correct, Although sometimes I think that the TV Database is out of date, That’s just me. I’m currently using Filebot 4.7 using the {Plex} format for episodes.
The series that are missing its Cover art, Episode Art and Episode Synopsis are, Lucifer, Lie to Me and Marvels Daredevil.
I’m using the built in default scanner that Plex uses for its TV Shows category.
Is there another scanner and metadata agent that I should use for TV Shows?
K:\TV Shows\A - L\Hannibal 2013\Season 1\Hannibal S01E01.mp4
K:\TV Shows\A - L\Lucifer (2015)\Season 1\Lucifer S01E01.mp4
K:\TV Shows\A - L\Lie To Me\Season 1\Lie To Me Season 1 Episode 01.mp4
these have worked for me without any issues
Ensure your follder and naming is acurate and Try a library Refresh and give it a good 30+ minutes
I’m pretty sure I have the naming format correct, But the Metadata just isn’t showing up.
Check your scanner logs for more hints.
There might be issues with a couple of things if your files are remotely stored: 1) If you are using a mapped network drive designation, try using UNC instead (i.e., on Windows, instead of X:\TV Shows... use \\<servername>\TV Shows...); and, 2) the accented and non-english characters (e.g., Apéritif) in the filenames can impact scanning with certain platforms.
And, ofc, you can always try doing a Plex Dance with the problematic files to ensure the scanner takes a fresh whack at them…
But your logs files will provide you with better insight.
Hi! I think is a bug of this new release!
Since some previous versions i am having a problem on my metadata. My PLEX is set in PT-BR (Brazilian) and most of the times i update my library i am forced to edit the name o the movie because it downloads the content in PT-PT (Portugal). In Past this problem do not exist. The funny thing is that some movies that i had the info in PT-BR now only show in English!? Does not matter which engine i use (TheMovie Database or FreeBase) i am unable to correct that.
After this latest update (1.0.1.2396) i am having another metadata issue… Now with TV Shows! it does not download the content (same as images above). This happen with some shows and does not matter how i named the series still not finding the right content. So now i have metadata issues in movies and TV Series The series are Continnun and Marco Polo. I tried everything but i was unable to download the right content. I already check the TVDB site but even after check if those series are listed there and naming as PLEX need to be done i got nothing.
For now, the only solution for my problem was uninstall everything and clean all the files on my HD then downgrade to version (0.9.16.4). I will keep that way. I Still have the problem maning movies in PT-BR but the version works fine with TVDB and runs on ATV4 also has the capability to convert videos. That´s what i recommend.
I have same issue with a newly added serier into my library since 1.0.
In swedish the following serier cant be found, but they are available if I check thetvdb.com, but the scanner cant find info to “Arga Restuarangen” and “Saltön”.
I also try match them manual but they wont find a match. I have also checked thetvdb.plexapp.com, and they exist there too.
Any idea?
Work again since 1.0.2 for me. :slight_smile:
I have the same issue (Plex Pass, latest server version). For TV shows, all metadata is fetched correctly except of covers, they are just not loading. I’ve checked TheTVDB and they have covers available. Already deleted the metadata agent caches and tried again but nothing. Any ideas?
I got the same problem with the TVdb Agent.
Newly added TV episodes do not load metadata correctly!
I am actually Running PMS 1.0.2.2413 on a QNAP.
Problem exists since a few days!
I already did the Plex Dance and a PMS Restart. Still the same problem!
Would be glad to get feedback!
There’s an issue with plex tvdb and using a different language than English. The dev’s are aware and will investigate. I have no more info than that. Sorry for the trouble this is causing you all.
It’s good Plex team is already aware of it, thank you for the update!
Thanks for the Update Peter!
I have the same problem for tv shows, no metadata.
Running plex version 1.0.2.2413
I’ve now installed the latest PMS update which several metadata fixes included but still no metadata coming up :frowning:
same for me, German Language selected, Episode Info, Banner loading but no Posters with 1.0.3
I’m having the same issue as well, with all of the 1.0 versions, with a clean install on linux. I had to go all the way back to 0.9.17.3.2239-fe07491 and my shows are all showing up. It must have something to do with the Plex Movie agent or whatever it’s called. Then if I upgrade to the newest version everything is fine because it uses the same metadata. I hope this is fixed in 1.0 soon.
know issue
https://forums.plex.tv/discussion/225873/problem-to-retrieving-metadata-from-tvdb/p2#
OttoKerner (Plex ninja) Said :
The issue where non-english libraries are not getting metadata will only be fixed in 1.1.0
fix it in 1.1.0 soon i hope
This is crap. I have upgraded to 1.1 and am still having matching issues with TVDB just like i have for the last 3 versions!
How frigging hard is it to work out and fix?
Do also note that tvdb, the actual external site where Plex gets all data from, currently has a bug on their hand too. That bug was obscured by Plex own bugs before and is now currently being handled by tvdb. The geist of it was, as I recall, that tvdb prev reported an actual error to Plex when the metadata was empty for your language (it was here Plex bug lie, we didn’t fallback correctly), now tvdb just reports “empty” which breaks Plex logic. This will be handled soon. In the meantime, while thats being handled I’m sure that the dev’s would like to see your logs after a failed attempt to download metadata.
Thanks @Peter_W logs already supplied and many hours of testing and trialing complete. End result, i believe it is out of my control and i therefore have to wait for a resolution.
