I would like to instal a plex media player on a raspberry but i don’t find “Integrated Platform” on download page.
Can you help me ?
Can you help me ?
Raspberry Pi is not supported anymore, at least officially. You can try Rasplex which is still working even though there is not much development.
Still exists as a community project (ie Not from Plex directly):
So I used the image file from latest-full and got it up and running…great! However, I need to SSH into it to change some screen settings in the pi config file. Unfortunately I have no idea what the IP of the pi is for sure so I’m hunting around connected devices on my router and found several that get me to a login. What is the login for these distributions? I’ve tried the default pi login but that doesn’t work. Suggestions?
Does this work?
Yes, that worked. Thanks! Now to find where the video config file is. I know where it is in Raspbian but this is a different structure. I have a 7" touchscreen and the dimensions are 800x480. Thank you, again.
So, just installed on a new msd card but it does nothing on my Pi4. Am I missing something? Green light will not stay on for more than a few seconds, so it is not booting. Do I need to add something to the config file? Advice?
I do have Volumio working on another card but I would like to try a Plex Client.
