I’d like to know if somebody has already successfully build Plex Media Player on Raspberry Pi 3 ?
I understand that there are full OS images available for raspberry pi (that work great by the way)
But the Operation System provided on those images is Read only. I can’t find any documentation about it but it seems to be a kind of OpenElec based OS. But a few programs are missing on it (For example LCD driver and software)
So I’m wondering if this is possible to install Raspbian and then compile Plex Media Player on it. (or any working plex client)
That could be great !
+1: the PMP image isn’t sufficiently up to date to support my audio card, whereas Raspbian is - the only documentation I’ve found so far is on the github repository: https://github.com/plexinc/plex-media-player
I’m going to give that a try, but I think there will be a lot of dependency chasing.
Then reboot and type asound -l to see if the sound card is detected.
Anyway I’de like to try to build PMP on Raspbian someday but It needs a lot of time
I hadn’t edited the config.txt - will give that a go. However, I still haven’t managed to build PMP locally, due to an apparent file reference bug on make - User-Agent: curl/7.38.0
Host: nightlies.plex.tv
Accept: /
The requested URL returned error: 404 Not Found
So which image are you successfully using? very keen to know!
Back to the OP can I ask if this is an option yet?
He asked “So I’m wondering if this is possible to install Raspbian and then compile Plex Media Player on it. (or any working plex client). That could be great !”
I’d like to be able to have PMP as an app available on my RetroPie installation - I dont want to have to dual boot. Possible? I dont think using an addon to Kodi is really the same… or optimal!
I’m with @tomsimmons also. The current build of PMP embedded does not have Hifiberry cards nor does it have alsa installed. Also needs to work with Pi3B+ (which the latest 2.17.0 does but no alsa, etc.).
2019 no response and I’m in same situation. Want to use raspberry for Plex, browsing, remote desktop and web server. Anyone has a solution to this? Actually I’m using web browser with my local Plex page server to play but it’s a little laggy.
