How to enable 3D Support?
Hi there!
What do I have to change in my settings to enable 3D Support in RasPlex? Currently I’ve unchanged default settings.
I have a “Over / Under” 3D File and renamed it “TITLE.h-ou.mkv” but RasPlex does not recognize it automatically and change in 3D Mode? I have not Side-by-Side File to test it :(.
Or am I completely wrong and RasPlex isn’t able to tell my TV (Sony Bravia with Android TV) to change into 3D Mode. For Example: My PS4 can do it fine with my Blu-Rays.
Thanks for your help!
3D content has to have specific file name extensions, see this article http://kodi.wiki/view/3D
Regards
I renamed the file to TITLE.3d.htab.mkv / TITLE.3d.h-tab.mkv, refreshed the library and it didn’t work. It just shows the two images top over bottom. I’m not shure how it is supposed to work? Should it combine the image? Should it tell the tv device: Go in to 3D mode!?
I can’t figure out what I’m doing wrong.
I attached a picture of the image displayed on my TV after renaming.!
Did you put your TV in 3D mode?
Did you look at the 3D preferences.
Regards
The 3D preferences are unchanged.
No I didn’t, if I put my TV manually in 3D Mode, why should I rename the files for automatically recognition?
I think I misunderstood the concept for 3D Mode. If I put my TV in 3D mode it works fine. Currently I have one library for 3D and one for non 3D. Is it possible to use one library with “3D renaming”?
Sorry for these stupid questions.
@chenks: Yes, but as you told, I have to do it manually.
What should change on the UI if i rename my files? Maybe someone could send me an image? Should the UI be displayed twice? On top and bottom? It doesn’t :(.
EDIT: Finally I’m confused. Now, without doing anything he asked me how to display video. After selecting “same as video” it switched into 3D mode. But it only happened once, now it is gone and newer showed up again when I start the 3D movie. Strange behavior.
I tested 3D behavior.
When film starts with black screen the TV was in 2D mode.
I stopped the movie at a scene and restarted the movie from the position I stopped before.
Now, I think the side by side was recognized and the TV switched to 3D mode.
We have identified an issue related to 3D-switching in the current release, a fix to make 3D-switching work a little bit better will be included in next release.
Ive just had this discussion in a previous post about this my TV is the Samsung H6400 active and i have both H-OU and H-SBS files now my TV is active. I have Auto detect set on my PI3 when i play H-SBS it Auto detects that it is H-SBS on my TV and i don’t have to set the TV but when i play H-OU i have to set my TV to OVER and UNDER
