How to enable Program Guide and Live TV for other Plex Users?
Actually i just can see Prgram Guide when i am connectet as Admin but not when i am connected as user xyz.
How to fix it?
Currently only the Admin user is able to use the Live TV feature. I’m hoping this will be something Plex changes soon, as usual however Plex doesn’t release timelines for that sort of thing.
ok, thanks for inforation.
I hope its possible soon ^^
Oh man, this needs to be fixed. Ive been tooting plex’s horn and telling my users to try the awesome new program guide. But they couldnt see it. Now i know whyyyy
Use the hdhomerun viewer channel for now.
How to fix it?
If you are using a silicondust tuner use this plex channel for the time being until your client/users is supported officially:
https://forums.plex.tv/discussion/101755/rel-hdhomerun-viewer/p1
Configure it and then share the newly created Channels category with whomever you want. It also works on any client that does not support the official Plex LiveTV… including “Home user Members”
