I would like to find out how to file a bug? Any assistance would be appreciated.
You make a post here with logs and all the details you can scrape together and, probably, someone will try to help you.
There is also info on how to report issues in the Community Guidelines
See: https://support.plex.tv/hc/en-us/articles/220049328
Scroll down to Reporting Issues
Not necessarily here, though. Preferably in the appropriate forum for the app you are reporting on.
Based on this info:
I need to supply the following info in a post in the appropriate forum:
Here’s what we need to efficiently analyze an issue:
- The specific app and/or server version being used and device it is being used on
- The steps to reproduce (use screenshots where appropriate)
- Provide current and expected behavior
- Log files (if possible) Log location info
Is this correct?
Ideally, yes.
@williammanda yes, along with a thorough description of your issue. The more relevant details you can give the people trying to help, the better.
