How to have Collections appear as a row in Home Screen
I want to have my collections appear as a row in my home screen (I am a Plex Pass subscriber).
I navigate to the “Collections” view in my Library, but even if I select them all, I can’t create a smart collection, which I can then make visible on my home screen. I also thought to create an advanced filter based on “Collection” and then add each and every movie collection to the filter and save it as a smart collection, but it seems it’s a “dumb way” to do it, let alone that this is not dynamic.
Is there an easier way to have the Collections view appear as a row in my home screen?
On the Collections view of your library hover over the poster of the collection you’d like to see on the home screen. From the 3-dot menu at the bottom-right, select Visible On and then the location(s) where you’d like it to be visible (Library for the library’s recommended view, Home for the home screen).
Note: Each individual collection you do this for will show as its own hub in the chosen location(s). So, if you publish 8 collections to the home screen, they’ll appear as 8 different hubs (rows).
Image of the menu options available when clicking the 3-dot menu on the collection:
Thank you for your time and your response.
This is exactly my problem; I don’t want each individual collection to appear as a different row; I want all my collections to be in the same row, scrolling each collection left to right . Is this feasible?
No, it’s not.
There’s no option to show a hub of collections.
That’s disappointing. Seems such a basic feature, to be able to view your library by collection from your stream box and select which one to start binging on.
Thank you for your response, though, Tom. Much appreciated!
