Is there a qay to hide certain libraries in rasplex? The reason for this since I switched to running PMS on a VPS I want to exclude Plex Cloud without deleting all the libraries there.
I would appreciate if anybody knows how to do this. Possibly manually specifying the server might do the trick?
there is an option to hide CloudSync
Preferences / the photo icon / general / Hide CloudSync sections
expect an option to hide PlexCloud soon
another simple way is by using plexhome and unshare that server for that user
@videotecaCNSU said:
there is an option to hide CloudSyncPreferences / the photo icon / general / Hide CloudSync sections
Creating a managed user is something I already thought about, probably the fastest solution to what I want to do.
yes, much simpler than editing skins for hiding it
True. I also wanted to convince the wife that she should watch stuff under her own user. This is probably the time I will gently force her to do so ![]()
If you leave “automatic sign in” on she will never know she is in another managed user
I am not at home so I can’t check, but can I specify which user is automatically signed in? Or how would I select her user to be the automatic one?
If you have it off, a menu will appear at start and you will have to choose the user and enter the pin if needed (very similar to netflix)
If you have it on it will always start on the last user
There is a bug there that sometimes it doesnt remember the correct user unless you enter to some of the library folders
If you have it on it will always start on the last userThere is a bug there that sometimes it doesnt remember the correct user unless you enter to some of the library folders
I see, that is what I expected. So maybe I myself just remember to re-log into her user after I have watched something myself. How would I treat shows we watch together then? ![]()
I dont think PHT or Rasplex supports binge watching right now, so thats not really an issue as it wont automatically start on the last episode
I didn’t mean binge watching, but just that the wifey and I watch some shows together, while users you watch solely on our own. So I was searching for a solution for the shows we watch together. I decided to watch them with the admin user as we did until this point and only the separate shows are watched under the respective manage user.
yes, its a good idea to have a “family” profile for those
