I have 2 friends who share their librarys with me, but I want my Rasplex to only connect to my local Plex server. I set the server to “Manual” and set the IP of it, but on main menu, it keeps showing my friends libraries. Is there a way to hide them or just let the Rasplex to connect to my local plex server?
You would have to not log into Rasplex and set the allowed networks pref in your server to allow IP of local subnet devices also Plex Home or a PIN cannot be used which would also put security on server so rasplex could see your server. Or sign into rasplex with a different account you make that has access to your server but not your friends.
Mmmm… your last idea… Maybe use managed account, but won’t be able to track progress on my account then…
yeah its definitely not an optimal solution. you might be able to I have heard of folks using the trakttv plugin to sync there watch state to it so maybe you can use it to sync a it back to your regular account. ( not something i have ever attempted so no idea if that would even work and might need a reg account not a managed one )
