Is there a way to remove specific libraries on a 'per client' basis?
I'm still on the fence about whether or not to subscribe to Plex Pass - and I know I can restrict certain material on a 'per user' basis if I subscribe.  I've not played around with Plex enough to make up my mind, but in the meantime, I'm wondering if I can remove certain libraries for certain machines.
Example:  I've got Rasplex box 1 and Rasplex box 2 (both feeding from a windows PMS).
I'd like Rasplex 1 to have all of the libraries which are installed on my PMS.  However, on Rasplex 2, I'd like to hide a few libraries.  I thought maybe there was an .xml file somewhere amidst the file system on my client boxes which I could edit, for example menu.xml, and just comment out the titles of the hidden libraries so they don't display.
Thoughts?
Thanks!
Thoughts?
Thanks!
Why not just create a second Plex.tv account and share only the libraries you want to share with Rasplex 2, and login on Rasplex 2 with the new Plex account. Or you could wait until Plex Home is available.
Regards
Wouldn’t that require running 2 instances if pms?
Wouldn't that require running 2 instances if pms?
No you would be sharing selected libraries,
See this article https://support.plex.tv/hc/en-us/articles/204226753-Friends
You’re my new hero. Officially.
