How to ignore TV directories with .plexignore?
Server Version#: 1.40.0.7998
Hello,
I reorganized all of my TV shows. They’re all within individual folders and every show folder is named like this:
\showname1 (year) {tvdb-nnnnn1}
\showname2 (year) {tvdb-nnnnn2}
\showname3 (year) {tvdb-nnnnn3}
etc.
There are many shows in the same root folder. Most of them still need work naming the seasons and specials. So, I don’t want Plex scanner to see them all. Only some are ready. Others I want Plex to scan as I make them ready. I’d prefer to keep them in place, rather than use the Plex dance. I tested putting a .plexignore file containing a single asterisk in each folder, but that didn’t work. I’m thinking of putting a .plexignore file in the root that would list all of the folders, but I’m a) not sure if it would work, and b) unsure of the syntax. I certainly wouldn’t mind a better idea, as well.
So… Could I just put a directory list in the .plexignore file? Like this (using the above example)? I’d be fine with it. Then I could simple comment or delete lines as finish editing the TV show data.
(I know how to create a folder list: “dir /ad /b > list.txt”)
There are too many folders to make a test feasible. I’d also like to avoid making the server work too hard.
Never mind. I was able to answer my own question. My first attempt failed because I didn’t have asterisks before and after the folder name. Adding them worked. The necessity for wild cards is not obvious to me.
A simpler solution could be to create a staging folder outside your library folder where you prepare your media. Once you’re set you can move it to your target folder and let Plex add it to your library.
Thanks. I know. The problem is there are other programs locking the folders and files in place. So, it isn’t really a simpler solution.
Enclosing the folder names with asterisks did it. I like the control of having a file to edit.
