how to index albums with multiple CDs & repeating track numbers
I have Talking Heads, Sand In The Vaseline, Disks 1 & 2.
How do I need to prepare them so that Plex groks this?  I put them in separate directories, 'Sand In The Vaseline Disc One' and 'Two', respectively, but it is merging them.  Then, of course, the track numbers are wrong, so it lists Track 1 of Disc Two right after Track 1 of Disc One.
Any insights (short of reading the scanner code) would be appreciated.
The expected way to handle this is with the TPOS (Part of a Set) tag, with values of "1/2" and "2/2" respectively. Unfortunately Plex will list them as separate albums which makes it very annoying to try to play the entire set. The other option of course would be to number the tracks sequentially but then you lose the sense of the original media.
