I do prefer to have each disc have it’s own entry. I don’t mind if it merges them into one. However, its really inconsistent and driving me nuts. I tag all my files the same and it merges some… splits the others… Ideas?
The Eminem album shows up as (Disc 1) with both discs in the tracks listing
Not going to use that folder structure. It’s ugly and shouldn’t matter.
Step two doesn’t explain why it merges some and not others when they are all tagged the same way.
It’s obviously possible to have each disc as a separate album since it does with half of mine.
Tried it in Emby and they every one of my multi discs show up perfectly… :neutral:
ROFL at “set Discnumber correctly” The only difference between what you showed and my example of Eminem is mine showing the entire album (both discs) as (Disc 1). And that is coming from the ALBUM tag not the disc number tag. Obviously PLEX can see both your disc 2/2 example and the way i have done it.
You have yet to explain why it merges some and not others when they are all tagged the exact same way.
Music on PLEX is an afterthought to me so I’d very much like to know before i even consider re-tagging a couple thousand FLAC rips to the way one person recommends.
EDIT: The easiest way to get what i want is to just remove all disc number tags entirely. Leaving the (Disc X) in the album tag. Not sure this is something i want to do just yet.
