How to install 2nd server on same machine
Server Version#: 1.27.2.5929
Player Version#: 4.76.1
I found a reference to a similar question from +7 years ago, but the referenced articles no longer exist. As it’s been so long I’m hoping this is now achievable.
I’ve noted that keeping a folder hidden from the youth doesn’t keep them from seeing content when “searching”. They may not be able to access it, but it still comes up in the search.
Therefore a separate server seems appropriate.
Seems a bit archaic to have to run a complete separate hardware.
If you assign them a separate Plex user, you can completely hide a library from them.
https://support.plex.tv/articles/204234313-example-plex-home-setup/
I would go with a separate library, not a sever. Just dont give them access to the new library.
