I want to test the new 7.24 Plex beta on my new Shield to try out DV, gut the link to sign up for the beta program is broken: Join App Betas: Android (mobile), Android TV, Apple TV, iOS
can somebody fix it or is there any other way of trying it out?
I’m looking into this. Thanks for the report.
Also if you check this here, it doesn’t work: https://support.plex.tv/articles/201844613-early-access-beta-releases/
there is no option to set the update channel to PlexPass
Where are you looking for this setting? In the server settings? On the Plex website for downloads?
That link is for the downloads page which does have the Plex Pass option, but only if you have a Plex Pass. Your account doesn’t show you have a Plex Pass so you don’t get the option.
The Android TV beta is not automatically available to all Plex Pass users, it’s not the same as a Plex Pass preview version like for PMS. The beta needs you to actually sign up. The updates then automatically show up in the Play Store.
There are multiple levels of plex beta’s.
also
I purchased PlexPass yesterday, at least the status on my side is correct. But I guess it’s irrelevant, the link from the first post(http://goo.gl/forms/4W15otoWZDNBvXcq1) does not work.
since I have no way of selecting update channel in Plex Media Player on Shield I guess only option is opt-in beta via the above link, which does not work. So how do I get the 7.24 beta version of the player on my Shield?
You have patience until the link is fixed.
