Well, this will probably go better in future, but you can merge anything:
Even Death Wish with Grass - if that’ll help.
I suppose you also want to:
To keep Plex from borking the operation due to embedded metadata in MP4 files.
Well, what should “Merge” do?
It seems it does nothing…
It should give you a ‘Blue 2’.
“Select” both of those items of yours - the little circle in the upper left of the poster - then ‘Merge’.
Well, worked on 2nd attempt.
I need to check further but it seems to do the job.
Thanks.
There are a lot of moving parts and you’re new at this.
Soon, you’ll be showing others how it’s done.
… and STILL works better than Plex’s Optimizer.
