How to manually add Trailers? " plex movie agent wont pick them up "
Alot of trailers are missing and they are available, im not sure where plex movie agent grabs them , but how can i manually add a youtube link of the trailer to a metadata?
You can’t.
Youtube links are not supported.
Either you download the trailer itself and store it beside the movie file
https://support.plex.tv/articles/200220677-local-media-assets-movies/
or
you use this agent https://forums.plex.tv/discussion/253633/rel-trailer-addict-metadata-agent/p1#top
Im running 2 plex servers from the nvidia shield and the cloud … those this mean i cant install this because android doesn’t support channels ? or is there another way i can install it on android?
Unfortunately not. Neither Android nor Cloud support the installation of Plugins.
