how to play music .........
Hello
I have installed plexconnect and i works nice for movies , but when I try to manage may music collections I can only play selected item ....
I cant play a full folder or generate a list .
There is an option " suscribe " , but looks that nothing happen if it is selected .
It is a plexconnect problem ?
THx for help
Apple TV 3 , phyton 2.7 , plexconnect installed with git
runing media server 0.9.8.6.175-88ffbb2 on 10.8.4 OS X
Yep... music support is very experimental, "alpha" at best.
Thx for reply
I hope to enjoy playing full albums or manage audio list with plexconnect.
You have a mac with itunes and an appletv why not just use itunes & homesharing to manage/play you music for the time being?
Hey soy,
How have you been trying to manage your music? I have made a music section in my library and pointed at it my music folder on the computer. This seems to work, though admittedly I haven’t tested it extensively. The iTunes plugin doesn’t work so that route is not the way to go.
Well iTunes does  not allow OGG, APE and a lot of losseles audio .
I have not tried iTunes on plexconnect , it works nice alone, you can play full albums or manage list , but forget about other audio than mp3 , mp4 or apple audio formats.
iTunes plugin doesn't work? Should work the same as PMS libraries...
