How to restore Plex Library - Pls Help!
Server Version#: 1.25.0.5282
Player Version#: 4.71.0
Ubuntu 20.1
I followed to the letter this article Customizing your Plex configuration written by @ChuckPa
I moved my “Library/Application Support” from my server, as it was taking up to much space and filling up “/”, and moved it to a NFS mount on my Synology.
Everything seemed to well.
When I restarted the plex services and logged in, it did not load or find my data. It is writing logs to “Library/Application Support” on the NFS mount so I assume the permission are correct.
So I have all my Plex metadata moved. How do I get plex to pull it all back in and use it?
I have searched the forums and cannot find a clear answer.
Attached are logs. Any help is appreciated.
Plex Media Server.1.log (15.8 KB)
Plex Media Server.2.log (3.6 MB)
Plex Media Server.3.log (366.4 KB)
Plex Media Server.log (1.3 MB)
You should be able to copy the database back to where it was, but I would not expect a good outcome.
I seem to remember reading here over the years that locating the database on a remote system was generally unsupportable due to the lack of file locking capability of the protocols involved. Someone please correct me if I am wrong.
Did the guide you follow explicitly state that what you did was supported by example?
Not supported. Use at your own risk.
@Agster
Put it in /home (presuming you have a separate /home partition).
If you don’t,
  • Plug in a USB drive
  • MOUNT the USB drive as instructed in the FAQ so Linux treats it as native and not a transient drive
  • MOVE your Plex metadata there.
All these instructions are found in the Linux Tips
