Drokare
1
I changed the priority on the Agent to use Freebase, but it still defaults to TVDB.
TVDB won't find anything, but if I select Freebase, it finds the movie with no problems. I have to manually "Fix Incorrect Match" on everything.
Is there a setting I am not familiar with?
Win8.1x64
to change them main agent for a library you have to edit the library and under Advanced there is a drop down to change it.
https://support.plex.tv/hc/en-us/articles/200289266-Editing-Libraries
https://support.plex.tv/hc/en-us/articles/200241558
Drokare
3
Thanks BigWheel, I made the change.
