Server Version#: 1.16.1.1291
Player Version#:2.34.0.983
Where do you select how to sort the content of a Library or the individual files inside a Library?
You don’t mention which app you’re using, so the best I can do is refer you to the Help pages. Find the “Navigating…” guide for your app and it should have what you need.
Thanks for your reply, beckfield. I assume you mean the PLEX app for PC (Windows 10). I have a Library for TV and I want to specify how to sort 1 of the folders in that Library., I used to know where the “how to sort” preference menu was, but I have forgotten…
