How to stop credits autoskip countdown
Sometimes the end-credits button appears prematurely and with autoskip, after 5 seconds, the program is auto-terminated. That’s great if the end-credits are properly located, but when not, how do I stop the 5 second countdown so that the program continues uninterrupted.
I use an Nvidia Shield, and when I want to stop the auto-skip function on it I use the [BACK] key. The key that lets you go back one menu. I do not know if the Roku has a button for that feature, but if it does try pressing that when the countdown starts to stop it.
Thank you. The back key on the Roku does this as well.
