How to turn around a video clip
Hi!
Anyone that can tell me how to flip around a video? Have some of my own video clip from mobile phone that is upside down.
Cant find any way to turn them around in plex. The funny thing is that they are right turned in my computor but at the wrong way in plex?
Can someone help?
It’s funny how different phones handle this. From using the phone in a vertical vs horizontal position to flipped left and right (upside down). It can be very deceiving since the phones automatically flip as you rotate them.
One of the tips I can recommend is record a 1 minute video in each orientation while talking “sample in vertical position with home button at bottom”, sample in horizontal position with button home button to right", etc
Download them and add them to a test library and see how they look in Plex and what orientation is used. Then you will have a much better understanding of what you can and can’t do while taking videos to make life easier on you.
As trumpy81’s message shows Windows Live Movie Maker is one of the most popular ways to re-orient videos after the fact. You can also use VLC to do this which is cross platform.
Carlo
Hi Folk´s! Have tried this but on my computer in my folder the video clip is right turned but when plex is loading in the clip is on the wrong way? I have used Movie maker and turned the “Right” clip upside town just to test but it doesn´t seem to have any affect? The clip is still the same…not effected? Strange this…?
