how to use 2 plex media servers at once ?
now that it's officially possible, how do i do that ?
i have one pms normally with plexconnect and it's all good ..
so i just need to install only plex media server on the other mac ? or plexconnect too ?
thanks
succeed by only installin plex media server on the other mac :)
that's really awesome!
but what if we'll be able to choose in settings to show all plex media servers he will see at the same time ? in this way we won't have to move to settings when want to use another computer. the channels will merge into the channels tab and double channels will show only once and library will show folders from all plex media servers at the same time!
possible to do?
once myplex is integrated in plexconnect then this will be possible i guess....
Hm... to make this happen, PlexConnect would have to query multiple PMSs for XMLs and combine them into one XML sent to aTV.
It would be possible, I guess, but would need some major rewrite. I don't think it will have a good chance for implementation...
if you'll do it it will be so awesome!
think about it. in plex media server (in the web app..) it shows you all of the folders and channels from all discover plex media server at one place. if you'll have it in plexconnect and don't have to move to settings when want to change plex media server it'll make plexconnect even (much) better.
Probably would be easier to run one PMS using trailers app and the other using wsj app.
no it won't, cause now instead of one, you lost 2 apps!
baa, (intresting username by the way ;) ) think about it! it can be so awesome! all of the plex media severs folders and channels in one place without switching! it can be so cool!
But then... why do you run two PMSs, if you want their media undistinguishable combined in your client?
Yeah, well. Kind of born that way.
I have PMS on my unRAID and one on W7 for channels so would be nice to combine the two servers for one plexconnect
in case of  2 plex media servers it's 2 people using .. and if no need to switch it'll be much easier
baa in Thai means something like crazy  :D
SO WHAT do you say ? :)
To the Thai excursion? Not much. I guess, there are people thinking exactly that. And they might not be completely wrong... :-D
