How to view whats IN the trash?
Server Version#: Version 1.40.0.7775
Feature request = a trash bin that simply shows what’s in the trash
Why because currently it’s a mess to find whats in the trash. See screenshots.
So plex has a ‘trash’ bin system but no link to view the ‘trash bin’.
*All you get is a vague delete symbol in the library. *
Then you have to go inside a TV show then inside a season and then theres no more symbols.
You have to manually check each episode by doing get info.
I choose to not enable auto delete trash on library scan as a security feature.
You should be able to use the advanced filters to get exactly what is in the trash if you scope the filter for episodes:
Screenshot from 2024-01-04 18-43-47
Thanks.
Added screenshots to illustrate why plex could use a view ‘trash can’ button.
