Htpc for raspberry pi direct download
Hello everyone, I can not in any way install htpc in a rasoberry with raspbian.both using snap and flathub. Is it possible to have a direct link to the deb file?
Thank you
There is no build for the ARM architecture so it will not run on an RPi anyway.
There is no deb file because as stated elsewhere in these forums doing so would require building the app separately for each and every possible OS type and version. This in untenable which is why an app package was created for both snap and flatpak.
Thx for your quick reply. Tomorrow I try again. You can help me if I write the error message?
Grazie Francesco
