HTTP 429 when fetching certificate
Server Version#: v1.41.4.9463-630c9f557
My HTTPS connection not working, because my server not have certificate. I get the following lines in the log:
Feb 18, 2025 15:19:30.011 [11612] DEBUG - CERT: Certificate did not exist, fetching a new one.
Feb 18, 2025 15:19:30.012 [11612] DEBUG - [HCl#1d] HTTP requesting GET https://plex.tv/api/v2/devices/0650e818328a3221f7f8a7f11ea3fa51c1db79bb/certificate/subject
Feb 18, 2025 15:19:30.087 [4028] DEBUG - [HttpClient/HCl#1d] HTTP/1.1 (0.1s) 200 response from GET https://plex.tv/api/v2/devices/0650e818328a3221f7f8a7f11ea3fa51c1db79bb/certificate/subject (reused)
Feb 18, 2025 15:19:30.299 [11612] DEBUG - [HCl#1e] HTTP requesting PUT https://plex.tv/api/v2/devices/0650e818328a3221f7f8a7f11ea3fa51c1db79bb/certificate/csr?reason=missing&invalidIn=0
Feb 18, 2025 15:19:30.358 [4028] DEBUG - [HttpClient/HCl#1e] HTTP/1.1 (0.1s) 429 response from PUT https://plex.tv/api/v2/devices/0650e818328a3221f7f8a7f11ea3fa51c1db79bb/certificate/csr?reason=missing&invalidIn=0 (reused)
Feb 18, 2025 15:19:30.358 [11612] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
  <error code="1003" message="API rate limit exceeded" status="429"/>
</errors>
@torokb
I have reset your certificate.
Stop Plex.
Let it stay off for 20 minutes.
Start Plex
It should get a new certificate.
If not, please message me and I will look again at Plex.tv
Thank you!
It’s working!
