tomyun
July 28, 2018, 12:24am
1
PMS version: 1.13.4.5271 (macOS)
Experiencing a strange problem that all log files (in ~/Library/Logs/Plex Media Server/) have huge lines of DEBUG logs despite the relevant settings (i.e. Enable Plex Media Server debug/verbose logging) are all turned off.
Log settings were double-checked in the terminal and server was restarted a few times to ensure settings applied.
$ defaults read com.plexapp.plexmediaserver | grep -i Log
LogVerbose = 0;
logDebug = 0;
logTokens = 0;
Here are typical DEBUG messages found in the log files.
2018-07-27 17:05:14,532 (700011c14000) : DEBUG (runtime:717) - Handling request GET /system/:/prefs
2018-07-27 17:05:14,533 (700011c14000) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2018-07-27 17:05:14,534 (700011c14000) : DEBUG (runtime:814) - Found route matching /system/:/prefs
2018-07-27 17:05:14,535 (700011c14000) : DEBUG (runtime:88) - Sending packed state data (99 bytes)
2018-07-27 17:05:14,535 (700011c14000) : DEBUG (runtime:924) - Response: [200] MediaContainer, 418 bytes
2018-07-27 17:05:51,700 (70000f473000) : DEBUG (runtime:88) - Sending packed state data (114 bytes)
2018-07-27 17:05:51,700 (70000f473000) : DEBUG (runtime:924) - Response: [302] Redirect, 0 bytes
I’m seeing this also, just upgraded to 1.13.5.5291 today, not sure if this was normal behavior before.
Running PMS on: Linux version 4.4.0-92201708161632-generic (buildd@lcy01-18) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #0+mediatree+hauppauge-Ubuntu SMP Thu Aug 17 00:28:00 UTC 2017
Also, looks like verbose logging is off…
sudo cat Preferences.xml
<?xml version="1.0" encoding="utf-8"?>
<Preferences MachineIdentifier="....."
OldestPreviousVersion="1.0.3.2461-35f0caa"
ProcessedMachineIdentifier="..."
AnonymousMachineIdentifier="...."
agentAutoEnabled.com.plexapp.agents.lastfm.Artists.com.plexapp.agents.vevo="1"
GracenoteUser="..." MetricsEpoch="1" AcceptedEULA="1" FriendlyName="monolith"
PublishServerOnPlexOnlineKey="1" PlexOnlineToken="..."
PlexOnlineUsername="....." PlexOnlineMail="..." CertificateVersion="2"
PubSubServer="...." PubSubServerPing="15" LastAutomaticMappedPort="0"
ManualPortMappingMode="1" ManualPortMappingPort="..." LanguageInCloud="1"
CloudSyncNeedsUpdate="0" FSEventLibraryUpdatesEnabled="1"
GenerateChapterThumbBehavior="asap" ScheduledLibraryUpdatesEnabled="0" autoEmptyTrash="1"
FSEventLibraryPartialScanEnabled="1" DlnaEnabled="0" DlnaReportTimeline="0"
PubSubServerRegion="sjc" PlexOnlineHome="1" LanNetworksBandwidth=""
allowedNetworks="" TranscoderQuality="3"
HardwareAcceleratedCodecs="1" LogVerbose="0"
TranscoderThrottleBuffer="120"/>
Annddd, manually setting LogVerbose=“1” actually turns on verbose logs, but debug ones are still there.
Jul 28, 2018 00:41:07.489 [0x7f32ba7f2700] VERBOSE - * Host => 127.0.0.1:32400
Jul 28, 2018 00:41:07.489 [0x7f32ba7f2700] VERBOSE - * Icy-MetaData => 1
Jul 28, 2018 00:41:07.490 [0x7f32ba7f2700] DEBUG - Transcoder segment range: 571 - 636
Jul 28, 2018 00:41:07.490 [0x7f32d03ff700] DEBUG - Completed: [127.0.0.1:50600] 200 POST /video/:/transcode/session/dc3e6a621dbf637f073006e6929/51b69559-1d18-4659-8f3e-9e559977a870/seglist (11 live) 1ms 166 bytes
system
Closed
October 26, 2018, 7:11am
3
