'Huge' subtitles still too small on Android TV Box
Hello all,
I have Plex App installed from the Play Store on my android TV box.
When I select ‘huge’ subtitle (.srt) size, it is still a bit too small for my taste. Is there a way to make them ‘superhuge’ or ‘ultrahuge’ (without transcoding video)?
On my phone (also android) it does seem to work properly. Huge is actually ‘huge’ and fills up half the screen. While on the android TV box, it’s at least 2-3x smaller at the same ‘huge’ setting.
Thanks!
This has been a “bug” for quite some time now, “huge” subtitles are really huge when it’s being transcoded and burnt in, but when direct played, it’s a lot smaller.
Direct play and transcode renders different subtitle sizes, I would consider this a bug.
Has this bug been officially reported somewhere? I can’t find where to check that or to report it myself.
I have no idea, it seems this is the place to report bugs but plex people seldom reply here.
I will add a feature request in the correct section for it.
