Server version: 1.29.0.6244
app version: 9.9.0.35519
I don’t have control over subtitle size in server or client,
all works fine in web player
Any solutions?
Any solutions?
Have you already checked Settings > Advanced > Subtitles > Subtitle Size in the Android app? This should be considered when displaying text-based subtitles – I think this should also be respected if Plex will burn text-based subtitles into the video as part of a transcode.
I did, burn subtitles on server and in app is set to only image formats
sub size is set to huge
override is ticked
It happened overnight, yesterday I didn’t have any issues whatsoever with same movie
What override?
Does your media contain text-based subtitles or are they image-based (e.g. VOBSUB, PGS)?
Override included subtitle styling is on
I think subs are text based inside mkv container
This should only apply if you’re using highly formatted subtitles like ASS/SSA formats.
Can you verify?
Info should be available via Get Info from the movie’s context menu in Plex Web.
https://support.plex.tv/articles/201998867-investigate-media-information-and-formats/
Codec SRT
Language English
Language Tag en
Display Title English (SRT)
Extended Display Title English (SRT)
Maybe your problem is the same as Subtitles size issue on Android players since 9.7.0.34811 ?
exactly the same…
