Strange. Listen, no need to dig further until I’ve rebooted this and maybe tested it in 12.1. /dev/dri is present and the jail that holds an upgraded plex is happy, but who knows what’s going on here. This is either a difference between upgrading and fresh installing Plex, or it’s something in my system.
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - Codecs: testing hevc (decoder) with hwdevice vaapi
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - Codecs: hardware transcoding: testing API vaapi
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Generic error in an external library
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - Scaled up video bitrate to 244233Kbps based on 4.500000x fudge factor.
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - Scaled maximum bitrate for resolution reduction to 85783Kbps.
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - Wonder Woman - audio.channels limitation applies: 8 > 6
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - MDE: Wonder Woman: selected media 0 / 280
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - Streaming Resource: Adding session 0x80ee50218:4k8svt7zcc6607c3sjz0lgey which is using transcoder slot. Used slots is now 1
Apr 14, 2020 19:21:46.375 [0x810c89900] DEBUG - Streaming Resource: Added session 0x80ee50218:4k8svt7zcc6607c3sjz0lgey
Apr 14, 2020 19:21:46.376 [0x810c89900] DEBUG - Streaming Resource: Reached Decision id=280 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=280 part=(id=287 decision=transcode container=mp4 protocol=dash streams=(Video=(id=30 decision=transcode bitrate=85783 encoder=libx264 width=2276 height=1280) Audio=(id=31 decision=transcode bitrate=256 encoder=aac channels=2 rate=48000))))
Apr 14, 2020 19:21:46.376 [0x80bad0100] DEBUG - Completed: [192.168.3.2:58823] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F280&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=uip1ck4pshiu5pqwkc1c1fjs&subtitles=burn&Accept-Language=en (13 live) TLS GZIP 3ms 1306 bytes (pipelined: 5)
Apr 14, 2020 19:21:46.503 [0x80bad0600] DEBUG - Auth: authenticated user 1 as tbehrens@outlook.com
Apr 14, 2020 19:21:46.503 [0x810c89900] DEBUG - Request: [192.168.3.2:58823 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (13 live) TLS GZIP Signed-in Token (tbehrens@outlook.com)
Apr 14, 2020 19:21:46.503 [0x810c89900] DEBUG - Content-Length is -1 (of total: -1).
Apr 14, 2020 19:21:46.507 [0x80bad0100] DEBUG - Auth: authenticated user 1 as tbehrens@outlook.com
Apr 14, 2020 19:21:46.508 [0x810c89900] DEBUG - Request: [192.168.3.2:58824 (Subnet)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F280&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=uip1ck4pshiu5pqwkc1c1fjs&subtitles=burn&Accept-Language=en (13 live) TLS GZIP Signed-in Token (tbehrens@outlook.com)
Apr 14, 2020 19:21:46.508 [0x810c89900] DEBUG - Found session GUID of uip1ck4pshiu5pqwkc1c1fjs in session start.
Apr 14, 2020 19:21:46.508 [0x810c89900] DEBUG - TranscodeUniversalRequest: using augmented profile Microsoft Edge
Apr 14, 2020 19:21:46.508 [0x810c89900] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/280?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=4k8svt7zcc6607c3sjz0lgey
Apr 14, 2020 19:21:46.508 [0x810c89900] DEBUG - Auth: authenticated user 1 as tbehrens@outlook.com
Apr 14, 2020 19:21:46.510 [0x810c89900] DEBUG - We're going to try to auto-select an audio stream for account 1.
Apr 14, 2020 19:21:46.510 [0x810c89900] DEBUG - Selecting best audio stream for part ID 287 (autoselect: 1 language: en)
Apr 14, 2020 19:21:46.510 [0x810c89900] DEBUG - We're going to try to auto-select a subtitle.
Apr 14, 2020 19:21:46.510 [0x810c89900] DEBUG - Audio Stream: 31, Subtitle Stream: -1
Apr 14, 2020 19:21:46.511 [0x810c89900] DEBUG - Found session GUID of uip1ck4pshiu5pqwkc1c1fjs in session start.
Apr 14, 2020 19:21:46.511 [0x810c89900] DEBUG - Cleaning directory for session uip1ck4pshiu5pqwkc1c1fjs ()
Apr 14, 2020 19:21:46.511 [0x810c89900] DEBUG - Starting a transcode session uip1ck4pshiu5pqwkc1c1fjs at offset -1.0 (state=3)
Apr 14, 2020 19:21:46.511 [0x810c89900] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Apr 14, 2020 19:21:46.511 [0x810c89900] INFO - CodecManager: starting EAE at "/tmp/pms-2d8c4417-9221-4b88-9f17-9ca42c851932/EasyAudioEncoder"
Apr 14, 2020 19:21:46.511 [0x810c89900] DEBUG - Job running: '/config/Plex Media Server/Codecs/EasyAudioEncoder-652-freebsd-x86_64/EasyAudioEncoder/EasyAudioEncoder'
Apr 14, 2020 19:21:46.511 [0x810c89900] DEBUG - Jobs: Starting child process with pid 9580
Apr 14, 2020 19:21:46.512 [0x810c89900] DEBUG - [Universal] Using local file path instead of URL: /media/Movies/Wonder Woman/Wonder Woman_t00.mkv
Apr 14, 2020 19:21:46.512 [0x810c89900] DEBUG - TPU: hardware transcoding: zero-copy support not present
Apr 14, 2020 19:21:46.512 [0x810c89900] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
