Oh my!
Thank you.
Exactly as I thought.
I see you have a 1240 xeon? It is full QSV capable ?
Oh my!
Thank you.
It’s a Xeon 1240, but I have no idea what is “full QSV capable”
checking
Full QSV capable == Quck Sync Video for Hardware transcoding.
… which it’s not.
sorry, I didn’t know you mean that. Correct, it has not igpu:
~$ lshw -c video
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: MGA G200EH
vendor: Matrox Electronics Systems Ltd.
physical id: 0.1
bus info: pci@0000:01:00.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=mgag200 latency=0
resources: irq:16 memory:bf000000-bfffffff memory:fbce0000-fbce3fff memory:fb000000-fb7fffff memory:c0000-dffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
I’ve invited @jrniemand to join us here if it’s ok.
He has a Celeron 11th gen with the same problem
Super. thank you. Then my list of Intel Xeons is correct.
I was concerned I might have overlooked one.
Thank you for checking.
I’m going to start committing this into the scripting.
I have to change both the pre-install and post-tinstall scripts
If I can help you with anything you need, just let me know. I will have access to the Xeon for a few days more., then will be gone. My new home server is the i5 now
My Celeron is an 8th gen, not 11th. Here’s the output of the script for me.
#!/bin/sh
CPU="$(cat /proc/cpuinfo | grep 'model name' | head -1 | awk -F: '{print $2}' | sed -e 's/^ //')"
ASIC="$(echo $CPU | awk -F- '{print $2}')"
CPUSKU="$(echo $ASIC | awk '{print $1}'| tr -d '[A-Za-z]')"
echo \"$CPU\"
echo \"$ASIC\"
echo \"$CPUSKU\"
root@PLEX:/home/plex# ./pms.sh
"Intel(R) Celeron(R) G4900 CPU @ 3.10GHz"
That’s what I thought I would see. Celery processors don’t follow the naming of the other CPUs
This is where I need to be creative
I will likely need to add a whole new CPU class to the script.
Am I missing anything?
The Xeon is good. Let it go do its thing.
I only wished to confirm I hadn’t broken any of the string parsing (such a joy in shell scripts).
Such a PITA all in the effort to make installation more informative & helpful.
Is it possible you are missing Intel Pentium?
Should I wait for the new .deb? or do u think u can share with me what I should install?
Sorry ! LOL
Follow Intel’s installation instructions
Sorry Chuck, you know I’m not very good at this, so I need to double check everything because I’m always worried to screw up everything
Should I follow these instructions?
https://dgpu-docs.intel.com/installation-guides/ubuntu/ubuntu-focal.html
Or these instructions?
I’ve noticed the instructions on github didn’t include the part of the permissions and they have included 6 packages:
intel-gmmlib_21.1.3_amd64.deb
intel-igc-core_1.0.7423_amd64.deb
intel-igc-opencl_1.0.7423_amd64.deb
intel-opencl_21.21.19914_amd64.deb
intel-ocloc_21.21.19914_amd64.deb
intel-level-zero-gpu_1.1.19914_amd64.deb
And intel’s webpage included just 5:
intel-opencl-icd
level-zero
intel-media-va-driver-non-free
libmfx1
Sorry for being such a dumb…
Those are installed as far as I can tell
root@PLEX:~# dpkg -l | grep -i ocl
rc geoclue-2.0 2.5.2-1 amd64 geoinformation service
ii ocl-icd-libopencl1:amd64 2.2.12-2 amd64 Generic OpenCL ICD Loader
ii ocl-icd-opencl-dev:amd64 2.2.12-2 amd64 OpenCL development files
root@PLEX:~# dpkg -l | grep -i beignet
ii beignet-opencl-icd:amd64 1.3.2-6+b10 amd64 OpenCL library for Intel GPUs
Just like it shows:
#!/bin/sh
mkdir neo
cd neo
wget https://github.com/intel/compute-runtime/releases/download/21.21.19914/intel-gmmlib_21.1.3_amd64.deb
wget https://github.com/intel/intel-graphics-compiler/releases/download/igc-1.0.7423/intel-igc-core_1.0.7423_amd64.deb
wget https://github.com/intel/intel-graphics-compiler/releases/download/igc-1.0.7423/intel-igc-opencl_1.0.7423_amd64.deb
wget https://github.com/intel/compute-runtime/releases/download/21.21.19914/intel-opencl_21.21.19914_amd64.deb
wget https://github.com/intel/compute-runtime/releases/download/21.21.19914/intel-ocloc_21.21.19914_amd64.deb
wget https://github.com/intel/compute-runtime/releases/download/21.21.19914/intel-level-zero-gpu_1.1.19914_amd64.deb
sudo dpkg -i *.deb
Try these same Intel Compute Runtime as well.
I’m not sure if your CPU requires them. Maybe it does ?
