HW Transcoding does not use P2000 GPU
Hopefully this is the right place for this.
Intel i5 Gen 4 3 GHz
Win 10
NVidia P2000
Plex Pass
CPU basically always pegged at 100% when transcoding.
Dashboard does not show (hw) ever
BIOS
  • iGPU enabled
  • GPU as primary
I’ve tried uninstalling and reinstalling latest Plex.
I’ve tried uninstalling and reinstalling latest Nvidia drivers.
I’ve tried unchecking :“Use HW encoding” rebooting. Checking it and rebooting. Still no dice.
Please help!
Attached are the logs.
Plex Media Server Logs_2020-06-26_19-35-28.zip (608.1 KB)
is there a monitor (or hdmi dummy plug) plugged into the pk2?
are you using remote desktop without the above?
are you running pms as normal, logged in, user (not a service) ?
If any of those answers = no, then
a) use a hdmi dummy plug or a real monitor
b) don’t use remote desktop
c) don’t try to run plex as a service
if none of those apply, try disabling the IGPU in the bios, and/or make sure p2k is configured as the primary display device (in windows display properties).
It looks like it is using NVDEC for decode, but can’t use NVENC due to a driver problem:
Jun 26, 2020 19:34:42.276 [7368] ERROR - [FFMPEG] - Driver does not support the required nvenc API version. Required: 9.0 Found: 7.1
Jun 26, 2020 19:34:42.276 [7368] ERROR - [FFMPEG] - The minimum required Nvidia driver for nvenc is 418.81 or newer
Jun 26, 2020 19:34:42.864 [6612] DEBUG - TPU: hardware transcoding: using hardware decode accelerator nvdec
Jun 26, 2020 19:34:42.865 [6612] DEBUG - TPU: hardware transcoding: zero-copy support not present
Jun 26, 2020 19:34:42.865 [6612] DEBUG - TPU: hardware transcoding: final decoder: nvdec, final encoder:
Are you using version 418.81 or newer?
You are right! I installed the wrong version fo the driver! Thank you so much!
