I can't figure out "Edit in Mix Builder..." -- possible bug?
First of all, a big Thank You for adding the “Edit in Mix Builder…” functionality, but I can’t figure out how it’s supposed to work.
What I would expect it to do:
Take me to the Mix Builder, but already have the artists selected which are in the mix, and allow me to either remove one or more of those artists, or add new ones.
What I’m seeing:
No matter which mix I click on, the Edit in Mix Builder… shows me NO pre-selected artists whatsoever, and the “artist picker” shows only unselected artists (kind of “greyed out”), and it shows the SAME list of 17 artists no matter which mix I choose. So if I go to my home page, select “The Cars Mix” and then “Edit in Mix Builder…”, it shows the same 17 artists as when I edit the “M83 Mix”, even though these are two very different genres/mixes.
It doesn’t matter if I choose to edit from Mixes For You or from Recent Plays. Same problem.
Seems like a bug?
If not, please let me know what I’m doing wrong.
Thanks!
Should be fixed in the next release, as well as we allow you to edit Sonic Adventures.
Good to know, many thanks!
Is there any ETA for when the fix will be released?
shouldn’t be long.
