I have about 6 raspberry pis set up with rasplex. All work perfectly however I can’t skip forward which is incredibly frustrating if I start a movie/show and don’t finish it. If I try to skip forward the video stops and I get an error, something about an unmounted drive, which is obviously not the case because it plays fine if I don’t skip forward. I believe they are just the raspberry pi 1s. I have installed all 3 different available version to see if it would fix it but it doesn’t. They used to work perfectly when I first set them up about 2 years ago then stopped probably around 18 months ago. I know it’s not an issue with my PMS because I have no issue doing this on my other plex devices (Samsung and plex for android). I am hoping there is just some simple setting I have put in wrong. If there is no easy solution I am happy to just leave them the way they are. It’s not a major issue, just a little annoying.
Anyone have any input?
From what you are telling it could be a lot of things
From the network being unable to keep up with the necessary bandwidth for fastfowarding, the server crashing, the server transcoding and unable to handle the speed for fastfowarding, or simply a new incompatibility between your version of rasplex or openphp and the server
I have some similar issues with some rpi3 on wifi, the wifi is really low powered and cant keep up with the traffic on high bitrate movies, and asking the device to fast forward or jump in time will most of the times wont work.
Even in the context of a wired network with multiple rasplex I had to use a traffic shapping solution to have a stable network. Its one of those issues that you start to notice when you have multiple 10mbit streams in your home.
I don’t believe it’s an issue with bandwidth or the server crashing. Other devices can do it ok, just not the raspberry pis. About the transcoding thing. I assume if I change it to direct play it might help resolve this?
I really need to know your setup and what you are trying to reproduce, its hard to help you otherway plus is a game of testing everything and discarding that it isnt
and as I said, the wifi on the raspberries are garbage and if you try to send something with a big bitrate it will just fail
I have my pms on a Synology Nas. I have the raspberry pis plugged in, not on wifi. I also have a Samsung Blu-ray and androids that play it all properly. I think they’re all raspberry pi 1s if that matters?
Fixed it. Found that the force transcode setting was on. Turned it off and it’s working properly.
yes, if it transcode to a mpegts format you wont be able to resume or change position on the movie
If “Force Transcode” is disabled and skipping still doesn’t work… then what ?
is your server transcoding?
whats de video format?
