as you can see i can’t update… it’s blocked on “installing”
Update manually:
All you need to do is:
- Stop/quit/end Plex Server with the tray icon
- deinstall Plex Server with the regular ‘Apps’ control panel of Windows
(do not use 3rd party ‘Uninstaller’ software like Revo etc.
do not use “Registry Cleaner/optimizer” software like CCleaner et al) - for safety, reboot Windows
- download the installation exe of the newer version and install it
(If you want to install an older version of PMS, take a look into %LOCALAPPDATA%\Plex Media Server\Updates)
thank you so much… sorry if i have opened a new topic on this thread but after a WEEK i’ve seen 0 answers on italian one
edit. first problem
second problem if i try to install new version manually
Take a look at PMS-SHUTDOWN.MSI Error / FIXED! - #2 by HighJavier
as well as Windows: Errors trying to upgrade, install, or uninstall Plex Media Server | Plex Support
thanks again… i’m going to see that topic
Edit. i’ve solved with “Fix It” tool… thanks a lot again!!!
