I found a bug. Scanner will loop forever and movies won't appear!
I found a bug.
Version 1.14.0.5470
Linux
The scanner was using 25% of CPU all the time and not all movies were found/shown. It took several days so it is not because there was many files. Also I tried to restart several time and it was always not progressing. No progress after finding excatly each time 4 series (and the same ones)…
I found the issue.
my lib is
/media/movies
/media/series
I had symbolic link movies in /media/series to redirect to /media/movies.
Same in /media/movies a link to /media/series
According to the log the scanner was looping forever and was following the sym links.
When I removed the sym link everything was working fine.
Please raise this issue to the developpers so that they can fix the “forever looping scan for links/shortcuts”.
For example found in the log :
after removing the sym link :
Dec 04, 2018 15:14:42.468 [0x745cd3b0] VERBOSE - Permanently removing directory 74742: data/data/data/data/data/data/data/data/data/data/data/data/data/data/data/data/data/data/data/data/data/movie1
ofc this is show a forever loop of symlinks…
That is a bit of a … fringe situation, which would be fairly complicated to detect. But I appreciate the report!
