Which error was that again?
Please share screenshots if there is an error message on screen.
I have the screenshots in the first message, is the same
It shouldn’t show any libraries, let alone advise you to upgrade them.
If the database is gone, there would be no libraries to upgrade.
Did you move the plex data folder away from the default location, perhaps to make room on drive C:?
I have created two new libraries after deleting the folders that were recommended to me. Plex was completely empty of libraries. I have more than 40 gigabytes of space available
Then you did not use the default metadata agents, but picked once again one of the legacy agents.
This is the default agent for “Movies”-type libraries.
Which agent is selected in the other library?
Plex series (shows)
Could you show another screenshot for that, similar to the one from your movie library?
Yes, similar
Yes, that is the default agent for TV show libraries.
Curious why it would still warn you about old agents.
Are these the only libraries you have created?
Do you happen to have a second plex server?
What happens if you tell Plex to convert these libraries for you?
I have created a movie library and a series library.
I only have one plex server.
if I click on update, the last screenshot of the first message is shown.
