I get subtitles even if they are disabled
Server Version#: Latest
Player Version#: Unknown (Samsung TV, The Frame 2021)
I get subtitles even if they are disabled: https://pasteboard.co/Kjl6mel.png
When viewing the content on my Samsung TV (The Frame) I get the black subtitles. I have disabled subtitles in the TV. If I enable them I get two sets of subtitles.
When I view the content on the PC there I don’t get the black subtitles.
Looks like “EIA-608 closed captions”. These are encoded directly into the video stream and quite difficult to remove.
You will have to ask your TV device to not display them.
Hm, that could be something. I will need to investigate a bit. Thanks!
I will try this guide later:
Okay I found a solution - it seems that the Samsung guide did not work.
Instead I found out I could just remove the CC from the MKV directly.
This is done with this ffmpeg command
ffmpeg -i input.mkv -codec copy -bsf:v "filter_units=remove_types=6" output.mkv
