I need help with a library in plex, constantly scanning it
so i did the folder monitor increase, and the old amount i had was exactly the same.
This is an INotify warning
See: Synology FAQ - Questions, Answers, and How-To's - #22 by ChuckPa
Right but could that cause scanner problem like the author is seeing? I’d guess so but if not then maybe someone else could take a look at the logs.
How many media folders, in total across all shared folders containing media, including sub-folders, do you have ?
FileStation → Right-Click a shared folder name → Properties
– Will count the number of files and folders in that shared folder
Repeat for all shared folders containing media.
Total them all up, round up to the next multiple of 32768 (if you worry about keeping memory perfectly aligned). No matter the number, you need a minimum of 32 extra slots. The transcoder uses 2 for each activity. This gives you the potential for 16 transcoder activies (scan, analyze, transcode, etc)
Update the DSM settings using this method:
This technique applies to both DSM 6 and DSM 7.
Don’t forget to restart DSM after setting these values. They are not applied retroactively
Future reference: “[Notify]” and “no space left on device” means the table in the kernel is full (Notify table is a virtual device so the error text can be misleading)
Aug 15, 2022 13:28:16.216 [0x7f5dd454eb38] DEBUG - [Notify] Now watching "/volume1/media/tv_shows/Bridgerton/Season 02"
Aug 15, 2022 13:28:16.216 [0x7f5dd454eb38] DEBUG - [Notify] Now watching "/volume1/media/tv_shows/Bridgerton/Season 01"
Aug 15, 2022 13:28:16.217 [0x7f5dd454eb38] DEBUG - [Notify] Now watching "/volume1/media/tv_shows/The Sopranos"
Aug 15, 2022 13:28:16.217 [0x7f5dd454eb38] DEBUG - [Notify] Now watching "/volume1/media/tv_shows/The Sopranos/Season 05"
Aug 15, 2022 13:28:16.217 [0x7f5dd454eb38] DEBUG - [Notify] Now watching "/volume1/media/tv_shows/The Sopranos/Season 06"
Aug 15, 2022 13:28:16.218 [0x7f5dd454eb38] DEBUG - [Notify] Now watching "/volume1/media/tv_shows/The Sopranos/Season 02"
Aug 15, 2022 13:28:16.219 [0x7f5dd454eb38] DEBUG - [Notify] Now watching "/volume1/media/tv_shows/The Sopranos/Season 04"
Aug 15, 2022 13:28:16.219 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/The Sopranos/Season 01" (28: No space left on device)
Aug 15, 2022 13:28:16.220 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/The Sopranos/Season 03" (28: No space left on device)
Aug 15, 2022 13:28:16.220 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/Big Mouth" (28: No space left on device)
Aug 15, 2022 13:28:16.220 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/Big Mouth/Season 05" (28: No space left on device)
Aug 15, 2022 13:28:16.220 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/Big Mouth/Season 02" (28: No space left on device)
Aug 15, 2022 13:28:16.238 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/Big Mouth/Season 04" (28: No space left on device)
Aug 15, 2022 13:28:16.238 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/Big Mouth/Season 01" (28: No space left on device)
Aug 15, 2022 13:28:16.239 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/Big Mouth/Season 03" (28: No space left on device)
Aug 15, 2022 13:28:16.243 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/Smallville" (28: No space left on device)
Aug 15, 2022 13:28:16.243 [0x7f5dd454eb38] ERROR - [Notify] Failed to add watch for "/volume1/media/tv_shows/Smallville/Season 05" (28: No space left o
Thanks. I was looking at the text detail of the error (no space left…) and not the stack it came from (notify). Good tip for the future.
the same issues is back, i just increased my watch folder and it is now continuasly scanning my main movie library. its been scanning it for the past 2 days. this is getting very annoying as i have no way to fix it.
