I used Channels DVR, can I use Plex at the same time without causing difficulty?
I use Channels DVR, I find it very hard to use as far as more advanced configuration, such as adding live streams. I would like to try Plex, can I run both at the same time without causing problems? Also, I am blind, I use a voice over, the screen reader in the Apple TV. How does Plex work with voiceover?
You can run Plex and Channels DVR on the same machine, they use different TCP ports.
I run both as well no problem. Fair warning though, I found Channels after an abysmal experience with Plex’s live TV/DVR functionality, but this was a couple of years ago.
