If HDR is enabled. Refresh Rate change fails
Server Version#: 1.26.2.5797
Player Version#: 10.0.19044
When HDR is also enabled. Refresh Rate change fails on my System, Windows 10
UPDATE: added information
If change audio output during playback. Such as disconnect your headphones. The refresh rate will change. However! HDR will not be disabled ones playback ends…
It´s a known issue and probably be fixed in the next version.
