So, the new Fire TV Stick 4K Max from Amazon supports AV1 decoding natively.
Where is the AV1 support Plex? You really want to drive people to Emby?
+1 AV1 support
+1 for AV1 codec support!
Thank you
+1 AV1 support
+1 for AV1 support
+1 for av1 support
+1
Itās really annoying to have to convert all of the av1-encoded videos to h.264 one by one, but it can be done. It would just be so much simpler if av1 compatibility was added to Plex natively.
+1 for av1 support.
surprised this hasnāt yet been added after this long.
+1 for av1
AV1 is a open standard and a great codec. It really deserves some love.
Please add AV1 support.
+1 for av1 codec
+1 for av1 support
+1 for the future in video codecs
+1. I hope av1 get supported. Itās the obvious choice for video encoding now.
+1 to getting AV1 supportedā¦
+1. This is necessary for Plex to stay relevant. Even Jellyfin supports AV1, and thats free.
+1 for the AV1 support
Until this gets fixed, I use the āuse external playerā on android and then just use MX player to view my media.
Itās not ideal, but it gets the job done. Subtitles work too, but progress is not saved and if your connection is not fast enough transcoding is not possible.
Sure would like av1 support
