I guess I also come from a personal experience prospective. We’ve had tons of people ask for things that just aren’t possible, or go outside the established structure we have to live in. So no matter how much people ask for those things there’s nothing we can do. But if someone gives a request that takes those things into consideration we can at least try to find a way to do them. When someone tries to think of how it could be done, I’ll be honest most of the time they don’t have any idea & are way off the mark, but sometimes those ideas help us think of a way it could actually be done. Oddly enough they more often give us ideas on how other things we were working on could work, but at least it’s something. Fanciful ideas just make people happy to dream, but they’ll never go anywhere. I could put in a feature request to have plex detect when I need a refill & automatically refill my cup. & I could get 1 million votes. But anyone looking at suggestions won’t read a single comment because it is outside the scope of the system.
This is a discussion board about a feature suggestion. Every thing we talk about will be considered. I point out potential flaws to try to get others thinking in a more realistic direction. It does not mean those suggestions I dismiss are bad, just that from what I know, which is not a lot more than others, but I have been doing research into scanners because I want to edit an existing scanner to enable a thing I think is pretty simple. But the more I researched the more I learned how not simple it is. So when I see something that from what I know makes a problem I point it out. I know if I were reading through suggestions & got to something that isn’t possible I’m going to dismiss it, but if I see something that I can picture how it would work I’m going to start thinking about how to make it real. Once I’ve started I’m invested & more likely to try to do it.
As far as my use case, I personally have no problem with more menus. I think that’s fine. But I am used to having to be thinking about practicality. To be looking for holes. When I see an idea I feel has merit I’ll try to break it apart & look for problems or ways to make it better. I’m not going to do that for things I see as “fanciful ideas” that’ll never actually happen.
